configure cfm segment transmit-interval
configure cfm segment segment_name {frame-delay | frame loss}transmit-interval interval
Description
Configures the transmission interval of DMM frames.
Syntax Description
segment_name An alpha numeric string identifying the segment name.
frame-delay Y.1731 Ethernet Frame Delay Measurement.
frame loss Y.1731 Ethernet Frame Loss Measurement.
interval Specifies the transmit interval in seconds. The range is 1 to 90.
Default
10 seconds.
Usage Guidelines
Use this command to configure the delay between two consecutive DMM frames. The configured delay is for both continuous and on-demand transmission. This command is optional, and if not configured the default interval is used.
The following example configures a transmission interval of 5 seconds for segment s2.
configure cfm segment s2 transmit-interval 5
This command was first available in ExtremeXOS 12.3.
Platform Availability
